Hey Y'all. Bought a 97 Max off craigslist. After reading on the site I was able to get most things to working order. Adjusted all the chains, bands, fluids, cleaned the carb and its working much better now. Figured out from reading that the trans makes some crazy poping noises but they went away after a quart of lucas atf and additive.
A few questions I have for my fellow max owners are...
Is it normal for the exhaust to glow red from running the engine at max rpm?
Is it normal for the clutch and pulley to use only half of the available surface on their pulleys? photo(7).jpg Seems like if it was using all the available pulley face it would be faster, its kinda slow now.
IF that is normal is there a way to mod or adjust it to make it faster?
All the lube points I have found is the 2 jack shafts and i behind each wheel. Any others?
Still trying to find a stumble in the engine, at steady rpms it kinds surges just a little and when the RPMS slightly drop from the surge there is a faint poping from the carb. 18HP vanguard
any advise is welcome.
