Installing a HF 3,000# winch. Installed the fabricated winch mount with backing plate and am going to mount the wiring block to the backing plate. Where is everyone routing the power cables? I want to avoid the chain trough entirely and can't go over the frame at the front as that is a pinch point. I wanted to avoid drilling a hole in the frame if possible.
Additionally, are you using a rubber grommet going through the top of the body? Does anyone think an AGM battery help or be any better than the lawnmower batteries these seem to be made for. Sort of wanted to not overtax a battery by winching and can't really install a larger battery as it doesn't look like there is any more room.
If anyone has installed one of these HF units I would appreciate their input.
I haven't done much swimming with this and also wanted to install a bilge pump but wasn't sure to mount that either.
Again any comments or assistance is appreciated.
