Max IV Idlers
They were in many of the 90's models, the later cast ones were much better if the bearing stayed in place.sigpic
Are sprocket type idlers the way to go on a Max IV or are there better solutions? I've read a few other posts about using delrin rollers, skateboard wheels and other various chain tensioners. Do the plastic type rollers provide less friction? Do they wear faster? What are the pros and cons?
I think a quality plastic will be longer wearing than a metal sprocket adjuster. Less friction means less time adjusting the chain. I have two types of UHMW that I've been experimenting with. One is the skateboard wheel that adjusts chain on an 80+ horsepower engine. Very little wear and tear so far.
The other type of adjuster is a semi-floating / in both a manual and partially self adjusting mechanism. I have these on a Max4 with a 25 hp engine. The self adjusting version still has some bugs in it.
I don't have enough time on the prototypes to say this is the solution however. I think they do show promise though.
Originally posted by jerseybigfoot View Post
I've been looking for some online, but am coming up short. A bigger version of these seems like it would work.
Update - Still been looking...Skateboard wheels are expensive! I started looking at casters like this:
RWM Casters POB-0312-06 3" Diameter X 1-1/4" Width Polyolefin Wheel With Ball Bearing, 250 lbs Capacity: Plate Casters: Amazon.com: Industrial & Scientific
or maybe this?
