Order of parts install for max vi axles
  • Order of parts install for max vi axles
    Finally putting my 2007 max vi back together. I swapped out my phone during this rebuild and lost my pictures to refer to. Can someone verify the placement of small shim, large shim, snap ring, and sprockets for front, middle, and rear axles please? I am also doing the 72mm Argo bearing install on these axles at the same time.
    Also need a close up picture of the front disc brakes and emergency brake so I can verify I have them installed properly. Thanks!
    The max shop manuals on this site have fair drawings. The transmission is installed first and the rear sprockets align with trany output sprockets. Center and front sprockets are measured from frame to same dimentions as rear one. Look at the axle and sprocket replacement sections of the manual.
      Check the Max ATV factory website for some really great photos of the chains, sprockets and brakes. The spacer stack up is machine specific. The sprockets need to be aligned using the spacers.
