max iv inner bearings
  • max iv inner bearings
    OK so I bought bearings today and applied industrial got me the wrong one need help on where I can buy the bearings(inner)
    Need to know if your axles are 1.250 on the inner end or 1.062. The turned end axles use a UC206-17 the straight axles use HC 206-20. Both should be relubable. Inner flanges didn't have zerks in older vehicles. I always install lube flanges if they weren't. Hope this helps.
      Its a 2000 and they are turned down the guy gave me hc 206 -20 way to sloppy so it has to be the 206-17 then
        Yes it takes the uc 206-17. The setscrew side of the race faces the axle. Btw the 17 is ID in 1/16 inches. Not all bearing houses stock the 17s. Buffalo bearing does.
          Ordered from them only had 2 in stock gotta wait lol for more
