drive belt size or number
  • drive belt size or number
    Hi guys!! Have an old max with the 2 stroke jlo and I need a drive belt number or brand.I have no serial # to give but it has the inner bushings on axles and old flotation tires so im guessing late 70's thanks for all your help in advance!!!
    Only thing I have is half a tag with 3 serial numbers starting with 463. If that would help anybody!! Thanks
      Believe all the singles used 15026 Max belt, their site lists it still available 88.22. If you have the tin 2 piece engine mounts that is probably it.
        Thanks for info!! Does anyone know the dimensions of this belt?? I can buy these type of belts from motion industries for about 35 bux all day if I knew the actual length and width!! thanks again guy!!����
          Just looked at my old notes and find "All big max 340-400-440 Daco 1078". supposed to be 46 5/8" x 1 3/16" Don't remember where this came from but hope it helps out.
            Oh thank you. I've been tryin to find a belt that will fit correctly!!!
