Hello again. I was examining all the chains on my 1996 Max II and noticed that the right side (passenger side) chain assembly - the vertical one is very loose. It appears as if you could remove a whole link to tighten it. I have no idea how it got like that as I bought the machine used and also had someone install a new engine last spring. The other parallel chains running the sprockets appear to have the correct tension. How can this be corrected - replacing the chain - adjusting the jackshaft ? If I make an adjustment to tighten this chain, what effect will it have on the other chains? Looking for advice. Thank you.
If it was loose enough to slap the bulkhead panel forward of it, it's new chain time.
