I think I have an extra set of good condition #50 chain sprockets floating around.
New to forum and 6 wheelers
These t20's on their best day shift pretty tough. Don't let the gears grind.
Rocking it back and forth, and my trick that works is to pull the sticks back, press the shifter down gently, let them snap forward. It will usually fall into gear.
Your t20 operates like two divorced differentials, meaning the operate independently from each side. The best mod to make it shift easier, is to cut the shifter in half so you can shift each side independently, so they won't fight eachother when trying to shift. It's much easier to line up one gear at a time than two simontaniously, it also gives you the option to run one side in forward and the other in reverse.sigpic
welded up split shift - Amphibious ATV Pictures
This photo in the gallery is te best example I could find of the easiest split shifter.sigpic
If you can find a small hollow pipe that will slide around the shaft that ties the two together, cut it, slide it over, (the pipe keeps the levers straight) weld the extra pipe onto it to make a "T" shape, and just get a ball from an old lawn mower or replacement from a hardware store. There's a lot of different ways to do it, when I get mine done il post pics and a parts list.sigpic
