I believe you are speaking about the factory rubber tracks. I've seen it done, the wheel base is longer on the Max4 which necessitates lengthening the tracks. The most professional looking conversion I've seen had six splices cut into the tracks with aluminum plates, the plates had three holes each to adjust as necessary.
Factory track belts for the max 4 are 16 " longer than the 2. I have a set of factory track that had three splices in them. I removed the 16" piece and installed on my II.
The Max IV tracks are longer. If you have a set of the Max 2 waffle tracks I have some cut off pieces and splicing we could make the extensions you need. If you are interested let me know. My office number is 260-768-7221 ex 103
