Hi all,
Model: '94 Max II
Serial: 10608
I'm about to redo all of the bearings for the axles and would like confirmation I have selected the right items for purchase. The items are written how I envisioned they would fit onto the axle. Am i missing anything? That 15014 flange, can i use that on the inside of the tub as well? I see there is currently one on my Max.
62mm locking collar --- 15283 Outer 3 Hole Flange Greasable --- 15012 Bearing 62mm --- ???paper gasket (i see one available at max6x6)??? --- 15014 Outer 3 Hole Flange Non-Greaseable --- caulk strips---- (inside of tub) 15014 Outer 3 Hole Flange Non-Greaseable --- 15010 Axle End Bushing (Inner)
So if the above is correct, the shopping list would be as follows:
6 x 15283 Outer 3 Hole Flange Greasable
12 x 15014 Outer 3 Hole Flange Non-Greaseable
6 x 15012 Bearing 62mm with Locking Collar
6 x 15010 Axle End Bushing (Inner)
6 x 30075 GASKET, FLANGE PAPER OUTER BEARING - MAX II
6 x 1ft caulk strip
Thank you for any feedback, hoping to order today or tomorrow to have the parts for the long upcoming weekend!
Gilby
Model: '94 Max II
Serial: 10608
6 x 1ft caulk strip
Gilby
