id have to ask someone at ri to be shure but i know it was single cylender jlo engines from 69-mid 70's had the #40 axle chain with idlers. when they brought out the big max with the twin cyl engine they started to use #50 axle chain with slide adjusters. then sometime in the mid 70's they just made them all #50 axle chain.
Adjusting chains on a Max II
Willtx
Below is what I used on my 2000 Max II, Hope it helps, Been 37 hrs on the chain and no stretch yet. I am very happy with the chain and bearings.
Chains, MFG Supply
Nomenclature
5200-ring-102-w1-520 O-ring chain 102 pins $159.12
520O-CL-W1 - 520 O-Ring Motorcycle Chain Connecting Link 5 $19.95
530O-RING - 530 O-Ring ATV Chain. 182 pin 182 pin $89.18
530O-CL-W1 - 530 O-RIng Motorcycle Chain Connecting Lin $19.95
Total $288.20
Buffalo Bearing, 714-874-1720
Nomenclature Qty Price Total
HC 207-20 R3 outer bearing 6 $17.44 $104.64
SA206-20 Inner bearing 6 $13.07 $78.42
PF207 outer bearing plate 6 sets $12.96 $77.76
There is more chains that need adjusted than I thought. Thought it was only the chains on the jack shaft, but i found out today that a couple of the chains are so loose that they are actually laying on the inside of the body. Wish i knew somebody that knew how to adjust all of the chains. I guess this is why i having popping noises and can't spin on a dime
[/QUOTE]
I would recommend that you go with Snap Idle brand chain adjusters. They are a manually type adjusted floating tensioner, and you have to keep an eye on them after each ride. After you get some experience under your belt and start replacing things and building parts that work better, you can always make your own chain adjusters.
