Air duct or fan...anyone done it?
  • Air duct or fan...anyone done it?
    Noticed temps get high back there on my IV..
    Anyone ever ran a duct for fresh air to the motor from one of the side vents or run a fan for cool air intake into the engine compartment?
    Had to do it to my 2006/07 Argo 6x6 .... pre brake fan model , also added a hood fan to cool the engine compartment alone with the brake fan check out my photo gallery ...
    bg
        I'm thinking a duct from the right side vent for fresh air to the motor and maybe a small fan to pull air out...
        The duct work may be enough, but a small automotive fan on a switch wouldnt be overkill...found one that pulls 6 amps.
        Thanks for the ideas.
          My Hustler had problems with overheating and vapor locking so I installed an automotive fan on the rear that blows air into the engine compartment. I have it on a switch. It pulls about 4 amps. Got it off amazon.
            I plan to do the same. Instead I want to install it to the rear floor board upright (behind the passengers calf muscles, as it were. It will have a plug to dusconnect it when ever I need to remove the floor board.
            I figure pullibg fresh air under to the trans and up to the engine would be good.
