I was wondering if they make Adair tracks that work with a 24" Argo tires on a max IV?
Tracks for 24" tires?
You can use a curved board to shape the body once the plastic is heated. If your Max4 has a bump out on the side, you may have to adjust that as well or use wheel extensions to get the tracks out from the body.
Forum member K.G. Hills did different body reshaping technique by suspending his Max4 from ceiling beams and then welded in a support bar to retain the clearance.
