Guys I have a max iv with an 18hp b&s v-twin. My top speed is only 15-16mph. Is this normal? If not what should a look for as far as getting it to normal speed?
Normal speed?
speed
First thing I would look at is the drive belt. Make sure it's Not worn Thin. That will reduse your top speed and pulling power.
Alot of guys on here are out rideing and at events so getting a responce around this time of year is sometimes slow !
Make sure your drive and driven clutches are free and moveing also.
Plus everything id Lubed and free !
Hope this helps you some.
Tj
Originally posted by john swenson View Postkinda simple but also make sure throttle cable opening throttle all the way. john boy va.l like to buy stuff and no I don't do payments!
You can purchase a tachometer to check your RPM. I would start with the belt like wedge mentioned though. Make sure that it has the proper tension. You can tighten it up by adding spacers under the engine. As for the top speed, it will probably be in the mid 20's, definitely more then you are getting.
Originally posted by Mike View PostYou can purchase a tachometer to check your RPM. I would start with the belt like wedge mentioned though. Make sure that it has the proper tension. You can tighten it up by adding spacers under the engine. As for the top speed, it will probably be in the mid 20's, definitely more then you are getting.Max IV
Dodge Ram 2500 4x4
swamp buggy powered by 1947 willys flathead
It should go faster than 15. My Max IV easily goes 15 down our local 3rd St, near the school zone, which has a vehical speed guage. We can see our speed at a glance (its mounted to the speed sign). I do 15 at about half throttle. BTW I've never been full throttle yet.Stand for the Flag. Kneel for the Cross.
