Can someone help me identify? Sorry I don't have pics. I need to replace the sprockets between the t20 output and the rear axle (drive) sprocket. Is this an idler or adjuster? Anyone know off the top whats the tooth count or size? thanks...
Max IV sprockets...
All 6 are the same on the max4,buffalo truck runs 2 special ones. I purchase the ones from agri supply 17 tooth 1/2"
bore. These are a hardened tooth sprocket with replaceable bearing. The max used a rivited type with fixed bearings before the solid models of about 2000 model year. The G&G manufactured ones use a proprietary bearing that is a different OD than the standard bearings. Part # 30503 Agri SupplyLast edited by msafi65; 07-27-2015, 11:36 AM.
I was thinking of getting rid of the sprocket all together and replacing them with uhmd round stock roller style like the hustlers used. I've got the materials laying around to make a few. It seems as the rear tensioners have been known to have some issues like coming off the bearings, failing, and even hitting the t20 sprockets if not adjusted properly.l like to buy stuff and no I don't do payments!
Originally posted by amphibious drew View PostI was thinking of getting rid of the sprocket all together and replacing them with uhmd round stock roller style like the hustlers used.
