Hy , I was going the woods and it squealed and poped and won't steer left. Its been popping really bad the last month. I just wondered if someone could help? thanks alex and its a max iv
Won't turn
Popping generally equals chain/sprocket looseness. Check all the chains for tension and sprockets for teeth, if the sprockets have bolts through them check them for breakage.sigpic
Hey Jim,
What would cause the same sound and "no" turning assuming the chains n sprockets are working fine? Mine did this same thing and visually everything is still in place. I cringe to say this....maybe a broke/twisted band? This would really suck since I don't have 3 hours on it since I had the T-20 rebuilt
When you break a band the stick movement changes abruptly on the broken side ,usually will come back to seat or forward to dash after the pop. You broken a shift pin or shift collar grove. This can leave one side in neutral. Pull the engine and remove the diamond shifter on dead side. Inspect the pin and the grove in the shift collar. A quick check is just disconnect the dead side shift rod and try shifting it. You should feel the spring detents in three positions. if it just moves with no detents something broke ,likely the pin.
The pins are 1/4x 11/16 roller bearings. Available from max 6x6. Usually very hard to pull from diamond shifter. I suggest if it's broken flush to replace the shifter. I have a jig I made to drill the holes on the other side. I install a new pin and have a shifter for other side. You can get the retainer and shifter out without pulling the engine but very difficult to inspect the groove in the shift collar. When in the field without help I pull the rear seat and just walk the engine forward to do a trany. Good luck it's kind of a pain to have to tear down again.
