I bought a '96 Max IV recently and it's great in deep mud, trail riding, through shallow creeks, etc. I tried taking it for it's first "swim" the other day and wow...
This thing bobs like a cork and is uncontrollable in the water. I can't turn, and basically had to use a trolling motor to get back close land enough for the wheels to touch bottom so I could get out of the water. Am I doing something wrong ? I also have the trolling motor mounted on the rear and the prop was barely under water. Anyone mount a trolling motor on the front ? Does it work better ?
Also discovered a problem with the Briggs 16 HP..it was running rough and stalling. I discovered the welch plug on the carb was leaking vacuum. I replaced and resealed the plug and it runs great. Any tips on getting this thing "swimming" safely ? One thing that may have effected stability is that the previous owner MAY have overinflated the tires...they are very tight. What is the proper inflation for the Goodyear rawhides ? He has them at 12-14 psi each.
