Any remote greasing ideas for a maxIV. I am into a frame out, all new parts, rebuild. Is everyone taking all 6 wheels off after every mud hole to grease bearings??? Or is there something easier???
Grease
Hopefully I'm not jumping out of order but I had a few questions in regards to the greasing process. What type of grease are you using? I also noticed that mine shot grease past the seal after two pumps. I'm assuming I need to replace the seals? If so where's the best place to buy seals for a Max IV?
Originally posted by brian19600 View PostIf I could jump in and ask a question about seals:
I read on the board about some of you getting your bearings with the "r3" seal. Apparently this is a triple rubber seal - it seals out water better? Does it matter if your greasing regularly anyways?
I've got a Max I use just for ice fishing and use the same grease as in my other one. It gets thicker in the winter but it's made for wet applications which I think is more important. It sees a lot of slush. It's Mobile SCH. Everyone has their own grease they feel is better I'm not sure it matters. The more grease the less water that gets in. That's my long winded take on it for what it's worth.What it lacks in ground clearance it makes up for with traction.
