axle bushing?
  • axle bushing?
    Could anyone tell me the bushing size for the bushing that goes in the axle shaft then onto the stub shaft?
    Can you tell us some more about your 6x6? Year, make, model, etc.
      sure it's a 1974 Max II "BIG MAX" it has a 400cc j-lo but is getting a 25hp kohler.
        Axle bushings
        I have a 89 Max II. I replaced all of my axle bushings. Bought them at Graingers. They come in a three pack and around $10. To get the old ones out I used a tap and made threads on the inside of the bushing. Screwed in a real long bolt or threaded rod and made a puller type tool to force the bushing out. Then just press the new ones in.
          shabby ok? do you remember what the size of the bushing is? Thats what i'm trying to figure out so I can go buy some replacements. I'm looking to find out the ID x OD x lenth.
            I will check mine and get back with you on the inside and outside sizes.
              I got the bushing out and measured it up. The bushings are 1"od x 3/4"id x 1" long.
