Like the title says, I've been looking at Max IV's (used).
Most I see listed are better than an hour away, so I haven't actually got any seat time.
I currently have an Argo Vanguard II...it's okay, but seems small & the steering is a little clumsy IMOP.
The Argo is fine, I like the 2 speed trans, but what I see on YouTube it looks like the Max's are a little more "sporty".
I like the 2nd seat in the Max IV & the roll bar seems like it would be a big help to hold onto & swing in.
Am I correct that with the Max design you push the stick ahead to drive that side of the machine?
Are there any known weak points to look out for on used Max machines?
One that I'm looking at, the owner said that the front left wheel wanted to wobble on dry ground, would that be a simple outer bearing swap or a more complex repair?
Were all the Max IV's pretty much the same or any significant changes over the years?
The friend I bought my Argo from is obviously biased towards Argo, but felt that the frames & wheel bearings on the Max's were not as strong as the Argo's??
Sorry if I got "wordy", just trying to pick up all I can before I hook up the trailer & make a road trip.
