Hello All,
I didn't like the idea of the little 'disposable' drain plugs that are designed for the Max, and wanted something more reliable and removable.
I have fitted brass compression tank couplers, with rubber washers and endcaps.
Compression tank couplers:Plumbsure Brass Compression Tank Coupler (Dia)15 mm | Departments | DIY at B&Q
Endcaps: Plumbsure Brass Blanking Capnut (Dia)15mm | Departments | DIY at B&Q
I discarded one of the nuts and the olive that comes with the couplers, and used a hacksaw to reduce the length (with the nut wound on, so you can use it to clean the thread from the cut).
Then I drilled the drain holes slightly bigger, and fitted the couplers and end cap.
The idea is that the couplers stay in permanently, while the end caps can be removed to let water to drain out.
There are disadvantages, the coupler makes the hole slightly higher, so more water will stay in the Max, meaning it needs a bit more of incline to drain off any water that has accumulated.
Mainly, though, is that the fitting sticks out of the bottom and seems vulnerable, even with removing some of the excess length. However, the fittings do seem to be robust and well secured.
When the Max is up and running, I can report on how they perform.
What does everyone reckon? Is it a silly idea, will they just get ripped straight out?
If anyone wants pictures, I can post.
Interested to hear your feedback.
