1991 Max IV when i am running, I get a 14volt reading at the battery. Then I turn it off and it drops to 11.99volts. how can I trace where the the voltage is draining out? The battery is newer and if I charge it and let sit on the bench it won't drop below 12.12v so it is not the battery.
battery won't stay charged
If you have a test light you can turn the key off & then pull the fuses one at a time. When you pull the fuse put your testlight lin line where the fuse was. Ground to one fuse contact & probe to the other. If the test light doesn't come on there is no drain in that circuit. Replace the fuse & do the same with the next circuit. You should find ont that lights the test light dimly... That circuit is the culprit. Start a visual search of that circuit at that point...
One more thought...
If you leave it alone for a few days does the voltmeter still say 11.99? If so does the machine still start? There is always the possibility that the voltmeter is calibrated a little off... You are only talking about a difference of .13 volts. That's only a difference of 1% between 2 instruments if you are using the voltmeter in your machine for one reading and a different meter for the bench.
Opps. didn't read far enough the first time to see you already bench tested the batteryOriginally posted by chrissteve View Post1991 Max IV when i am running, I get a 14volt reading at the battery. Then I turn it off and it drops to 11.99volts. how can I trace where the the voltage is draining out? The battery is newer and if I charge it and let sit on the bench it won't drop below 12.12v so it is not the battery.
if you charge it up what is the voltage right after charging, sitting on the bench it should be higher than 12 volts after a fresh charge.Try using a amp meter to see if there is a drain on the battery when just sitting in the machine. AS some one else pointed out the diff between 12.12 and 11.9 is not a lot off differenceLast edited by Aahicnow; 03-02-2016, 09:52 AM.
