Now I noticed I have 1 flange on the outside and one the inside of 5 axles. the other axle has 2 flanges on out side and one on inside. I guess what I'm asking is how does the set up go on each axle. Do you need to change flanges every time you work on axle. Is there a big advantage to flanges with grease zerts if you use sealed bearings.
older max flanges
I'm not te most expirienced member here, but I do believe both flanges are supposed to be on the outside.
The flanges wrap around the bearing and cradle it. (On the outside of the tub)
I I'm not mistaken, I think all the outer flanges have grease zerks, the ones that don't most likely had them broken off. (Like 3 of my old ones are)sigpic
Also, you want to have grease zerks to purge the bearings of water. Naturally water WILL find its way into a bearing one way or another, so every so often purge it with water resistant marine grade grease to keep them running smoothly.
It sounds like your machines had a couple improper bearing jobs done maybe?sigpic
Rabbit929 has lead you down the right path. Check out the Max bearing replacement how-to for a video showing the bearings and flanges: How to Replace 6x6 Bearings
It is recommended to change flanges each time you change the bearings because the flanges will form to the bearings themselves when properly installed but a lot of people just reuse them. Even new flanges are tough to get seated properly where they will consistently supply grease to the bearing without leaking out around the bearing instead.
