I've seen the videos on the max 2 axle and bearing removal but there not even close to my 2000 max 4 setup. I get the idea but is there anything out there, as far as a video and tips for my max IV. Shafts are splined and yes it has the snap rings. I'm trying to remove all 6 axles. 2 days in and I have the front 2 hanging out of the tub, I'm trying to remove the break disk and sprocket which seem to be one piece.
Max IV axle video
You might need to check the end of the axle to make sure the bolt has been removed from the axle on the back side of the inner bearing. I did need to use a hammer to help jar my axles loose on my 2004 Max IV, but for the most part it is just like doing it for a Max II.Hold My B..R and Watch This!!!
Another thing to check is the set screws may be doubled up. Take them all the way out of the sprockets and squirt penetrating oil in then pull the axel in and out kind of like a slide hammer to jar the sprockets loose.What it lacks in ground clearance it makes up for with traction.
I just replaced a front axle on my Max IV a few months ago. My rotor and sprocket are 2 separate pieces, the rotor was free floating and the sprocket had set screws. The new replacement axle was a C-clip axle and I left both the rotor and sprocket floating between the clips (no set screws), I also had to face the rotor hub a few thou in order to expose the C-clip groove enough for the clips to seat.Originally posted by Delduck View PostI've seen the videos on the max 2 axle and bearing removal but there not even close to my 2000 max 4 setup. I get the idea but is there anything out there, as far as a video and tips for my max IV. Shafts are splined and yes it has the snap rings. I'm trying to remove all 6 axles. 2 days in and I have the front 2 hanging out of the tub, I'm trying to remove the break disk and sprocket which seem to be one piece.
The manual section on the home page of the forum has Max axle replacement instructions: Max ATV Manuals
Delduck... Did you get the front axles out?
We are now going to remove the right front axle on our 2005 M-IV tomorrow. The outer bearing is bad. Any other advice?
We are also doing the middle right side axle as well. There is a tiny bit of movement.
I hope the inner bearings are fine on both. Our new inners have not arrived yet.
Edit... I did read through the axle section of the manual a bit ago (I printed them out last year). It doesn't seem too differcult, but advice is always welcome.Last edited by Rusty-Gunn; 05-30-2016, 04:32 AM.Stand for the Flag. Kneel for the Cross.
We have been extremely busy with work so I'm loading the max up and taking it over to a mechanic that works on our tractors. The bad part is its planting season the good part is the mechanic has a world of knowledge about chain drive systems. With this being said I'm turning this nightmare over to him, I told him just try to save the axles. Lol
