Hello, I am in the process of changing out the bearings to our 2005 M-IX. The outer bearing I have are the HC207-20R3.
There is a steel pin inserted into the grease hole. Does thus mean this bearing is considered completely sealed, and can not be greased?
Or do I pull out this steel pin and line it up with the zerk? Thanks.
Unrelated rant... I ordered the wrong inner bearings. The Buffalo Bearing rep asked if my axles used the smaller bore bearings, or larger. I confessed I didn't know, and told him to send the larger 72mm. Well' my axles are turned down smaller on the ends.
I'll contact Buffalo Bearing and ask if I can trade them out.
