How did I do guys?
  • How did I do guys?
    Found myself a parts Max 2 missing wiring and engine. Owner said at least 3 axle bearings toast as well. I got 6 good tire/wheels, an upper body with all the if plates mine is missing, plus a 2nd T20. This one has solid axles can I swap them into mine that doesn't?
    Sounds like you picked up a good parts machine. You should be able to use the axles. What year is this Max?
      Not sure serial # is 15072
        I found s/n reference looks like it's a 1998
          If the machine has inner bearings then no.
            What year is your other Max? If it is many years older, why not just use this newer parts machine's frame, lower tub, axles, etc to build one machine?
              After what I found in the older complete unit today I might do just that.
                Well that's gonna make replacing the bearings a little more fun. Jeez, some people shouldn't be allowed access to welders.
                  I agree totally, I come from the fix it right school, instead of the cob-it-together school.
