I'm restoring a Max II with the Vanguard B&S engine. In removing the frame, engine, etc...as a unit, I damaged the flexible exhaust pipe. Is this something I can get locally, where???? Any ideas are appreciated.
Max II Flexible Exhaust Pipe
Originally posted by tenic View PostI'm restoring a Max II with the Vanguard B&S engine. In removing the frame, engine, etc...as a unit, I damaged the flexible exhaust pipe. Is this something I can get locally, where???? Any ideas are appreciated.1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )if it don't float with out you getting wet . don't bring it !
R.I.P sage rogers 4 11 09 .
doin;t you have to cut the end of the header off and weld the flex inside that then weld it back to the header robbie1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )if it don't float with out you getting wet . don't bring it !
