If I buy axle plow supports, can I buy a plow from northern hydraulics to hook up or is there a lot of gerry rigging to get the plow hooked up to the supports?
Axle plow supports?
 It is most likely not just going to bolt up. I think most of their plows that I have seen have a more narrow mounting point made to go between the tires of a standard ATV. Your side plates / plow supports will be wider. You would have to fabricate an attachment point by widening the plow mount. I don't think it would be difficult but it will most likely require a little work. Do you have a specific plow that you are considering?
 You might want to try these folks ATV Trailers : off-road ATV Trailers, carts, ATV wagons, equipment and accessories - Made in The USA by Country ATV. They make accessories for the MaxIV units. Good people to work with.
