I am puttting back together my 96 maxii and i need to know where the 2nd ground stap goes....i have the one from the battery to the frame....where does the 2nd one hookup too? Engine mount to ? Give me a shout..on hold till i get a good answer before i proceed. Thanks
Max ii 1996 14hp briggs ground strap location?
Yup right rear engine mount to the frame. If you got a grinder and a welder, you can weld it to the frame, and just spot weld it on the engine mount like I did, (so if you gotta pull the motor you can just knock it off with a chisel)
I had a lot of ground issues with mine, so I guess I kindof put a nail in that coffin.sigpic
