I just got this MAX 950T and been working on doing a few mods to modernize it. I made a custom stainless steel dash panel and mounted a Volt meter, dual USB port, dual magnetic phone mount and front and rear spot light switches. I have a vinyl printer and used some satin black vinyl to label the panel. I did away with amp meter and moved the hour meter to engine bay. I have LED light bar for front and LED spots for rear that I will update this post later once I build brush guards to mount them on. I replaced the rear tail lights with 6" oval flush mount lights and blacked them out with satin vinyl so thier wasn't too much red. I replaced the headlight bulbs with 6000k 54 LED bulbs that are much whiter and brighter than the factory bulbs and use a fraction of the current.
Upgrading my Max IV 950T with LED Lights and Custom Dash Panel
Here is the tail light. They had to be cut in but fit nicely. I made the black out on my vinyl cutter and could make some more if someone wants them?Originally posted by Rusty-Gunn View PostI am quite interested in the LED lights. Where can one buy them at? Are they direct bulb replacement s? Thanks.
9milelake Pair of 6" Oval LED Brake Light Stop Tail Turn Light for Trucks 12v Waterproof 10 Led w. Grommet+Wiring - Red https://www.amazon.com/dp/B018LO5TW0..._vg-ryb8ZDH74C
The headlight is a direct replacement bulb.
Bulbeats 800 Lumens 2pcs 54-BX Chipsets 1156 7506 1003 1141 1073 BA15S 1095 1073 LED Bulbs with Projector Interior RV Camper light,Back Up Reverse Lights,Tail Lights,Rv lights Xenon White 6000K https://www.amazon.com/dp/B01HI7D4VY..._Zi-rybVHD761V
