Just finishing up my 96 MAXII restoration and went for my first test drive. I have new chains - new bearings and tires all at 3.5in psi. I noticed a slight pull to the right when both sticks are sitting at the normal forward position under throttle. I am going to do a tire circumstance check tonight ..but my question is if all tires are proper circumstance - what is my next step for a true forward straight drive alignment? Go to the T20 trans for adjustments and best place to start? --- and if any tire is out of size circumstance from the others... do you adjust the pressure to match the size - even though it may not match the existing other tires psi?
Let me know what you have done to make it work.... Thanks
