Originally posted by egoperf
View Post
Max straight steering alignment
Thanks for the info I was wondereing the same thing! have 1 runamuck that seems to be larger than all the rest!
Yes,what egoperf said.
Sorry I can't find a better pic,but if ya look close you can see blue paint marker writing on the steel wheels. These runamuks are about 70.5/71" circumference at anywhere from a little less than 1 psi right through to about 3 psi. I just write the results on the wheel and set the air pressure accordingly. Then I generally put the ones with most psi on the "heavier" end of the machine. Front on my Argo 6x6,rear on my Attexs.
These tires are never the same. You are best off going by circumference rather than psi.
Just finishing up my 96 MAXII restoration and went for my first test drive. I have new chains - new bearings and tires all at 3.5in psi. I noticed a slight pull to the right when both sticks are sitting at the normal forward position under throttle. I am going to do a tire circumstance check tonight ..but my question is if all tires are proper circumstance - what is my next step for a true forward straight drive alignment? Go to the T20 trans for adjustments and best place to start? --- and if any tire is out of size circumstance from the others... do you adjust the pressure to match the size - even though it may not match the existing other tires psi?
Let me know what you have done to make it work.... ThanksTags: None
