Tracks may be the next purchase
  • #16
    Just got a max 1v (2001) what do I need to install tracks? Different size tires, wheel spacers etc? Thanks
    • #17
      Hi and welcome to the best amphibious site out there. Sounds like you're on the right track ( pun intended). To run tracks you will need 21x11x8 tires. I highly recommend k lock rims. You'll also need bearing cages if not already equipped. This gives you three bearings per axel and supports the axel all the way out to the hub. And yes you will also need wheel spacers.
