Max II chain issues
  • Max II chain issues
    My front and rear chains are super tight on the top, one of them ripped the nylon off the chain tensioner. The bottom of the chains are slack. How do I equalize the tension? Also the sprocket on the center axle under the jack shaft is out of place, it's too close to the body and caused the chain to jam against the side rails. I think there is a clamp on the axle that can be moved if I loosen a set screw? I seem to remember this from when I was replacing bearings and a snapped axle.
    Pictures here https://goo.gl/photos/ZgS31pp76YtPXqoY7
      What you are experiencing is the normal operation of any chain and sprocket system. If you think about the power flow between any two sprockets, one sprocket turns and pulls on the chain. That chain then pulls on the next sprocket. Because of this, a chain will be tight on one side and slack on the other. There is nothing wrong with that . The tensioners are designed to apply tension to the side that is slack during normal, forward operation.
      As for your tensioner issue, it was caused by your center sprocket being misaligned. Either your axle slid out some or your sprocket slid on the axle.
        This is abnormal tension, it is really really tight, zero deflection. I need to relieve the pressure. I found the lock collar to move the triple sprocket on the center drive shaft and moved it out of the way but the sprocket is not moving, due to chain tension I'm guessing. I loosened the jack shaft adjustment locking nuts. Is there any way to loosen the chain or should I unbolt the bearing holders off the frame?
          Sounds like something is bound up if the chain is that tight. Bad bearings maybe. Do you have the tires off the ground when checking the tension?
            make sure when adjusting the tensioners the wheels are off the ground and the trans in nuetral. rotate tires toward each other so the slack in the chain is on the tensioner side. hope this helps..... j.b.
              Just pull the master link in the chain and take the chain off. Even if you have to ruin the master link to get it out, it would be easier than pulling everything else out.
                Jack it up first.
                  Are you running tracks?
                    Yes I'm running tracks.
                    Oh fun master links. Ack! Takes me hours to get those buggers on and off! Oh well probably the best way as you say.
                    Yes I have it off the ground.
                    The binding is from the sprocket on the center drive shaft below the jackshaft shifting toward the frame and now the chain is rubbing on the frame and it seems to have caused other chains to slip on the other sprockets, I could hear them pop.
                      While it is not probable, once your chains are off check them carefully link by link as I just had an issue with 3 bent chains on a II where a few links in each chain became twisted or bent.
                      Mark will have something for you as far as chains and tracks.
