Originally posted by cabinfevrr
View Post
Max Noob - Nova Scotia
Originally posted by hipowerone View PostLook into what other registration options there might be. Down here in Vermont, there are land ATV's, water Boats, and then the not so obvious land or water "Any Surface Vehicle". All have different regulations and registration fees, but the ASV fits an AATV to a "T".
So I'm thinking this max iv isn't going to float too much.
One of the kids that goes to my daughter's daycare, her dad is a natural resources compliance officer (fish and game / conservation officer), and one of his duties would be to enforce the OHV act. I'm going to pick his brain next time I see him.
Did a little tinkering with my max IV yesterday. Replaced the fuel filter, had a good look at chain tensions. I have some work to do!
The story I got was that the chains were all replaced in the fall with 'harley davidson' chains. Anyone with half a mind knows that harley doesn't make their own chain, and most of their models are belt drive now anyway. I believe the story, because based on what I've read, the chains were put on by someone who hasn't read threads here. One of the front chains is singing tight, and the other side hits the belly of the tub when you go over a bump. The rear chains are also quite loose. The primary chains from the T-20 are loose, maybe an inch of deflection, but the rear double nut adjusters are maxed out. On the short primary chains there are 2 master links, so I'm thinking I have to back the adjusters all the way loose, take a link out and re-tension.
This is what happens when you take a max to a Harley dealership to have chains installed, apparently.
