BELTS....just one here. The or any DIRECT replacement drive belt name and part number for the RI Carlisle 018033 drive belt. Simple and all I am asking. It appears somewhere that not only has the Max brand not around anymore(AT ALL) but they apparent have never existed at all ever!!! That is atleast what answer I get anywhere I try to ask about a cross referenced replacement for it. I am talking the MANUFACTURERS on the phone making that claim. I know better ... then again are these belts actually some type of rebranded knock off. Sad when you can find a belt for a 40 year old machine but not a 14 year old machine without buying it thru the parts supplier directly and then...it is JUST that one belt . I KNOW BETTER THAN THAT. I worked directly with the bearings and belts on almost ever moving thing made. There are usually atleast 4 or more alternatives to ANYTHING....somewhere.
Too many threads.....just a simple answer please.
Dayco HP3017 is an equivilent.This company sells the belts you need...
Snowmobile Parts, Go Kart Parts, Lawnmower Parts, ATV Parts, and more | MFG SupplyLast edited by Rusty-Gunn; 03-10-2017, 04:19 AM.Stand for the Flag. Kneel for the Cross.
Recreatives Industries is the company your are looking for, belts are listed by manufacturer.sigpic
I read this before and bought two 1092M3 belts to replace my original 018033 belt on my 25HP Max. The 1092M3 belts I received are way too short to replace the 018033 belt that is on my machine. I have three original 018033 Recreatives belts here and two brand new 1092M3 Carlisle belts that do not fit at all. Perhaps they work on the smaller Briggs engines but they do not fit on the 25HP Kohler powered Max IVs. This makes no sense to me as I am strictly looking at part numbers when I order. If a 018033 fits a Briggs Max and fit my Kohler powered Max, then by default the 1092M3 should fit right?? Nope, not a chance.Originally posted by msafi65 View PostI use a 1092M3 Carlisle to replace a 018033 on a briggs powered max 4.
Here is a pic of a new Carlisle 1092M3 belt sitting on top of the Recreatives 018033 that came off my Max.
018039 is the factory belt for 25-29 horse max. It should measure 44 11/32 outside. The 018033 is briggs only and measures 42.5 outside. I run a Carlisle 1116 m3 on the 25-29 hp models. The magnum engine 4 ran a 1060 from the factory and is very difficult to install. I run a 1042M3 on all the 20-23 horse kohler max 4s. If I posted the wrong numbers at one time I apologize.
So this will indeed work with an 18hp Briggs on a Max 4? I think somebody need to tool up some type of automatic belt tension so various belt might be able to also be used. Anyway....any and all belts that can be purchased at Autozone,Napa,etc should be listed here too. I use to know the belts at NAPA but that was over 15 years ago.Originally posted by msafi65 View PostI use a 1092M3 Carlisle to replace a 018033 on a briggs powered max 4.
I'm not sure where I read it but thanks for the update! This is great information msafi65. There should be a sticky thread at the top of the forum just for part numbers and cross reference info on these machines. It's needed now more than ever with the current parts situation. I'll have to go back and check my factory belts, I could have sworn they were the 018033 belts that you said match the 1092M3 belts I bought but I'll hazard a guess that I made a mistake and they are most likely 018039Originally posted by msafi65 View Post018039 is the factory belt for 25-29 horse max. It should measure 44 11/32 outside. The 018033 is briggs only and measures 42.5 outside. I run a Carlisle 1116 m3 on the 25-29 hp models. The magnum engine 4 ran a 1060 from the factory and is very difficult to install. I run a 1042M3 on all the 20-23 horse kohler max 4s. If I posted the wrong numbers at one time I apologize.
