I have a 96 maxii with the older hollow axles.... Except the front right axle was previous replaced with the much heavier solid one. I have restored the entire machine and gotten a few rides in and now working out a few bugs. I have noticed the atv tends to slightly pull to the right and i have already did the tire pressure check as well as measuring each tire circumfance...which did help some. However, there is still a very slight pull to right and now i am wondering if the pull might be from the weight of the solid right front axle.?.. Or am i overthinking this? ... Possibly swap this axle to the rear?
Axle weight question on max ii
Are you pushing both sticks forward equally or relying on the spring pressure to drive it? Are the sticks even in movement travel?sigpic
Could also be the type ground you are riding on. I noticed mine will do the same on hard dirt but not on gravel or softer dirt trails (slightly muddy). I have adjusted the travel on the sticks and adjusted the plungers on the trans and did the tire thing as you described. Mine is still the same.
If I want one to travel perfectly straight usually end up with unequal air pressure side to side. 1/2 pound in air pressure makes a difference. I prefer mine to track left so I can drive on decent ground one handed. If you are thinking weight load something heavy in one side and try it.
