I broke an inner bearing mount on a rear axle. Any idea where to find another? It's an sa206-20 bearing with a 3.5" center to center between the mounting holes. The only ones I can find online are 4.5" (j=117mm). Thanks
Inner bearing mount Max ii
When you say bearing mount, are you talking about the pillow block that holds the bearing? If so, you can pick them up here: Max Atv Axle Bearings If you just want to find it as cheap as possible, search Google for "pillow block" and put in the size you are looking for.
