I just bought my first max ii, an 84. I've already made a deal to sell the 440 jlo 2 stroke and switch to a 4 stroke, my budget won't allow for a brand new engine at this point but I've had my eye on an opposed cylinder 18 horse Briggs.
My first question is will the opposed cylinder Briggs be a simple swap or is it a pain because of the cylinder arrangement?
What clutch should I run? Is one preferred over another or just stay away from Chinese junk? Also how much shaft do I need for said clutch? I'm finding engines wth 1 1/2-4" shafts.
Would I be able to upgrade to newer stye bearings and axles without alot of fab work? And would it be worth it or should I just upgrade to solid axles and bearing cages and keep it greased and stick with bushings?
I'm planning adding electronics like a stereo, led lighting, winch, power ports, maybe even a small inverter. Is an alternator going to take much power or won't make that much difference? I want to go with no less than 18 hp but depending what deal I find I may go as low as 14hp for the time being.
Fuel cell - are there any good ones floating around in southern Pennsylvania or should I just look at getting one of the hot rod ones from eBay? What are the dimensions on a factory round fuel cell? Mine doesn't leak but I'm not a fan of a home made cell with a pipe cap for a gas cap, or the sharp corners and slag to get cut on in the unfortunate occurance I flip or roll this thing.
Where is the best place to get sheets of hdpe online? I have a patch to make I didn't notice in the dark when I picked it up, I know never shop for vehicles in the dark but after 5 hours cooped up in my van and it being a running machine I just wanted to get loaded and head home. Also I want to make a one piece skid plate to go from front to back.
Is aluminum much, if any heavier than hdpe? I'm wanting to build a new bed from diamond tread that follows the factory body lines and bends and doesn't stick past the original body. I may break down and see about buying the upper in the parts forum but I'll cross that bridge when I get there.
I have a geo tracker soft top I'm going to attempt to use as a topper also, If it's not too terribly wide compared to the max. It might be kind of nice having a choice to have the bed closed in or run without back windows like a bikini style. Another bridge to cross at a later date . I'm going to start tearing the upper body and bed off tomorrow and get it jacked up and assess what all needs attention before I dig into the "fun" stuff that I don't need.
Thank you all for all your help.
