Guys that have done or have machines that are swapped to 4 stroke, how bad will my performance be with 18hp chonda and letting the driven clutch alone (2stroke) for the time being? I don't want to be frying my belt or breaking stuff. What should I expect? I'm planning to tune it or change it but it's not on top of the priority list at the moment.
Clutch question.
I'll post my 2 cents worth. I removed the 2 stroke from my max and installed a honda clone engine. I believe I ordered a new driver and driven that was a series 40D that was good up to 18hp. The set was around $85 and I had to buy a belt for $25 as well. The only catch was the driven did not have an internal keyway cut. I borrowed a broach and cut one myself in maybe 20 minutes. Could be done with a file or dremel as well I imagine. I haven't had any issues with mine so far. The belt is of course smaller than the original so I imagine it can handle the abuse a larger setup can, but for getting the thing running and having fun it was a cheap setup at just over $100
Originally posted by odskaggs2 View PostI'll post my 2 cents worth. I removed the 2 stroke from my max and installed a honda clone engine. I believe I ordered a new driver and driven that was a series 40D that was good up to 18hp. The set was around $85 and I had to buy a belt for $25 as well. The only catch was the driven did not have an internal keyway cut. I borrowed a broach and cut one myself in maybe 20 minutes. Could be done with a file or dremel as well I imagine. I haven't had any issues with mine so far. The belt is of course smaller than the original so I imagine it can handle the abuse a larger setup can, but for getting the thing running and having fun it was a cheap setup at just over $100DanW
