I have a 1995 MaxII with a 14hp Vanguard. A member on this site hooked me up with a way to bypass the governor and it really increased the top end considerably (I was averaging 12-15mph and now it runs 25mph plus). Only problem now is with the engine revving higher, the motor gets quite a bit hotter. I was thinking about going to a local junkyard and getting a small electric fan out of a junk car and mounting it to blow air on the motor. Has anyone done this and can you post a picture of how you did it? Thanks, RR
Max II cooling fan ideas?
This is what I did with mine, I have not installed a fan yet, I want to draw the heat away from the engine instead of blowing cooler air onto it. My engine shroud does a good job of brining in Cooling air, This does seem to help alot with the heat leaving the engine bay, In addition I want to pipe wrap my exhaust pipes in the tub also
This is a different application, but it was inexpensive and works very well. I had cooling problems with the BFD after the diesel was installed. In fact, even with the engine cover removed it would overheat in cool weather. The two fans were from ebay and cost about $25, shipping included if I remember right. One blows air in to the front of the radiator and we reversed the polarity on the other to run backwards and draw hot air away from the exhaust side. There have been no more overheat problems. I'd be willing to bet that a similar system would work for the air-cooled Max. [IMG][/IMG][IMG]
[/IMG]
I cut the engine cover and placed expanded metal on it to allow the heat to escape, that worked well and the 18hp in my tan Max2 never overheated again. I live in Texas where it pretty much stays hot.
[/url][/IMG]
I purchased a SPAL Electric waterproof/dust proof/shock proof fan off of summit racing and wired into my key switch so it is on when the key is on. I have a fan shroud on my passenger side to draw air past motor and the fan helps draw heat from the internal exhaust out of the body. works awesome as my motor ran extremely hot inside the body. Just one fan moves plenty of air. I thought of running two but haven't needed this far. I have attached directly to my expanded metal on the driverside
i am curious when your motor heated up did it run uneven, etc .? i put the 21 h.p. vanguard in my max 2 and even with the engine cover off it still runs hot. tends to miss some when taking off and when trying to climb a hill , etc. this is only when it's warm outside...otherwise no problems. it's a new motor so i figure the irregular running is the heat build up.... so i will get a fan also..was just wondering if that's the symptoms of it getting hot. johnboy va.
Originally posted by john swenson View Posti am curious when your motor heated up did it run uneven, etc .? i put the 21 h.p. vanguard in my max 2 and even with the engine cover off it still runs hot. tends to miss some when taking off and when trying to climb a hill , etc. this is only when it's warm outside...otherwise no problems. it's a new motor so i figure the irregular running is the heat build up.... so i will get a fan also..was just wondering if that's the symptoms of it getting hot. johnboy va.
