I just completed "Maximus". I took an older stock Max II and modified everything except the headlights and dash. This was a "proof of concept" that I wanted to try some different ideas on. I know it's not for everyone but I had fun doing it.
Here is a brief summary of the mods:
1. Re-designed the frame for stock Argo component ie: axles, bearings, seals
2. Beefed up frame.
3. Re-located battery to front
4. Eliminated Jack Shaft.
5. Re-built T-20, up sized input shaft from 7/8" to 1" dia., went to 12 tooth
#60 sprockets.
6. Re-located T-20 to where battery was, centered it, and raised it 2"
7. Installed 31 hp. Vanguard
8. Installed full size rear disc brakes.
9. Installed full width suspension bench seat.
10.Installed new front diamond plate floor.
11.Re-designed chain tensioners
12.Installed dual prop system, with shroud
13.Installed 30" Mud-Lites (30x12x12)
14.Installed off-set 18" center tires.
15.New ROP
16.Re-designed laterals and shift lever on T-20 and shift linkage
17.Re-worked tub clearances for 30" tires.
18.All chain and sprocket #60 HD
If you are interested any any of these mods or hi-res pics PM or email me. I will post some of them in the gallery under "Maximus"
2. Beefed up frame.
#60 sprockets.
15.New ROP
I,m also curious as to how well the smaller middle wheel will work out when you try to drive over a large log , or over the top of an incline with a flat top ?
