Mud bug tires on a max II?
  • #16
    s-l300.jpg after all of this i may end up buying 6 of these. They are 24x11-10 swamp witch tires. Seems pretty nice. Look like they MAY swim, and the price seems great. Thanks guys.
    • #17
      another good tire place to check prices besides '' moto sports '' is '' midwest traction ''. johnboy va.
      • #18
        So I just ordered 6 of those swamp witch tires from simpletire.com for only $400 delivered. I hope they work well. Now just need to order the rims from Jim's tire. If I get the orange rims they are like $80 total cheaper but the offset is 2.5/6 and don't know if I want that much tire hanging out. The grey ones he sells are 3.5/5 I think.
        • #19
          I wasn't able to find the swamp witches on that website, do you have a link? Thanks!
          To have adventures, you must go places where adventures can happen.
          • #20
            • #21
              Started swapping on the new tires. They fit awesome and will only need a little clearancing if the body to not rub. Will post some outside pictures soon.
              • #22
                Looks great!
                • #23
                  yes sir...big and aggressive !!! johnboy va.
                  • #24
                    Got them fully installed and molded the body. Noel, I ended up doing the two humps instead of stretching the whole body. I couldn't see getting a decent fit for the upper tub and thought the seat pan would fit goofy if I did more than just the 2 humps. Although I also only have 24" tires so didn't need a ton. You can see the side picture the two humps above the tires.
                    • #25
                      Couldn't look any better! I think you will really enjoy the tires, and the wheels look great too.
                      • #26
                        Check out a picture I posted under Gene Boyd. I made a set of bead lock rims. I cut 12 rings and welded six to wheels. Then drill and taped rims, drilled clearance holes. A LOT of work.
                        • #27
                          monk....those do look great and a good price !! let us know how they tear thru the mud..... j.b.
                          • #28
                            I can say so far they ride awesome. And we have only got a couple snow storms but in the deeper ditch snow they really tear through it. Much better than my old rawhides did at least.
                            • #29
                              Do the swamp witch tires swim?
                              • #30
                                They do swim some, not as fast as the rawhide though. There have been a few threads recently on how to improve your tires swimming abilities. I plan to try some of these tricks this summer. Water is a little hard right now in WI
