SLight Pull To the LEft Max II
  • #16
    check out the '' dryglide '' throttle cable on line. guaranteed no '' freezing or sticking '' . reasonable price too. johnboy va.
    • #17
      Duh, that makes sense now with the rain. Mine stays in the garage but regardless that is a good point. May take it out hang it up let gravity do its thing. @johnboy whats the site for that? Thanks for the info on not mixing throttle cables.
      • #18
        If anyone knows where I can get a roof/windshield I would be very appreciative.
        • #19
          lowcountry... just punch in '' dryglide freeze proof throttle cables '' . i'm going to get one for my max 2. j.b.
          • #20
            I did that but the vendor I am finding has one that is 6', dunno if the ends will work?
            • #21
              the one they sell called '' dryglide main throttle cable '' ( $ 24.00 )) you can get with one end that has a ball.. this would be the throttle handle end and the other end you can get a adjustable barrell for briggs,kholer, etc. on my 21 h.p. briggs vanguard i don't need anything on the carb end of the cable. it just hooks to the carb linkage thru a hole and tighten a set screw. the adjustment barrell is on my max 2 throttle handle. hope this helps, what is your motor ? johnboy va.
