Thought you guys might like to see how I built a under seat storage box for the back seat of my MAX IV.
1. Start with a flip up seat hinge (Richard sells a kit if you can’t build one)
Storage box in Max IV by Dane Trask, on Flickr
2. Build a (negative) template for the inside dimensions of the box. I used a new flat screen tv box from the garbage.
3. Optional put some foam insulation strips to create “Channels” in the inside of the box for separators.
4. Fiberglas the box upside down. The flange on the table will become the mounting surface that will rest on the frame of the seat.
5. Pull out the internal structure, cut separators, I used an old lawn sign. Then paint and go.
6. I also ran a wide piece of window weather stripping along the whole top and when the seat comes down it seals up pretty good.
