Still trying to work the last bug out of my recently restored 96 maxII. I have a slight drift to right and yes I did check psi and tire circumference multiple times as well as running less psi on left just to try it out. I have new bearings and chains and everything seems to be inline straight. **I can bump back occassionally on the left lateral just slightly about an inch or so as I go and it does straighten out, then slowly starts the right drift again when I release the left lateral.** Also I just remeasured/reset the t20 trans channel adjustments but still has the slight drift to right. I am thinking if I still need to make a slight tweek to one of the band adjustments/plunger on the left?? which one and which way? Will appreciate all input and advice !!
Max 11 drifting to right
Sorry, can't offer any advice to fix your issue. But, I have the same year MaxII as you and I have had the exact same issue in the eight years I've owned it. Tried all the possible remedies, but cannot get it to run straight. Absolutely drives me insane and one of the main reasons I use it only for ice fishing (with tracks) or clearing brush around my property. No joy rides simply because of the drift issue here.
