Max IV reverse on one side ?
  • Max IV reverse on one side ?
    I recently purchased a 2001 Max IV. It will go straight back in reverse and will turn on one side, but when I try to turn on the opposite side, nothing happens. Could this be an adjustment issue ? No problems whatsoever in forward.
    If you have no problems in forward I would assume one side is not going into reverse. I would place it in reverse and shut off machine, get out and visibly check that both diamond shifters are pointing rearward, if not you can shift the side by hand and then start up and try it again. If it works fine adjustment or learning the shifting process is the issue, if not could be another common issue.
    There are pinch points so be careful.
      I know this is probably a dumb question, but where are the diamond shifters ?
        There are no dumb questions. Just ones that need answering. Jim will tell you that the diamond shifters are where the linkage shifts the t-20 trans. they are shaped like a diamond and right on top of each side of the trans.
          Thank you
            I agree with Jim but you may have to go a step further. Remove the diamond shifter from the trans there will be a little pin on the bottom, if it’s wore your machine will give you a problem. I just finished putting 2 new ones in my 4. I ordered them from Richard
              Am I correct ? Do you have to pull the engine out to change them ?
                Hi pdugas, not sure if u have to remove the engine. kind of doubt it. But if your pins are worn you can heat up the barrel that they are pressed into and pull and turn them over. Just did it to my Hustler. You should post where you are. Another member could be close enough to help you. Good luck Mike
                  I pulled the table and engine on mine. It was easier, I also changed the trans fluid and made all the electrical connections to a plug. So now I just take the 4 9/16bolts out then unplug the connector remove the belt and off it comes.
                    Looks like this is the way to go. It would be very difficult to get my hand between the engine mount and the transmission.
                      It is a pita. A lot easier pull the table
                        On my 2000 MaxIV, there is a hatch on the table for the passenger side diamond shifter to be removed. On the left side (drivers side) I used and engine lift and unbolted the table legs to get an extra few inches to get the diamond shifter out. Did it this fall. Passenger side pin was worn, drivers side no wear.
