I was hoping for a little help, I'm not really good with carbs. I have a 1997 Max IV with an 18hp vanguard motor. The motor runs good from idle to full throttle but sticks at full throttle. Once I get to full throttle, the linkage stays there until I manually push the linkage closed. The previous owner adjusted the throttle cable so it only went to 3/4 open, so I think he had the same problem. I've attached a few pictures. Could I be missing a spring? If not, what causes the throttle to come off wide open?
Vanguard carb sticking at full throttle
It's the semi round piece that the throttle cable attaches to, I assume that's the governor linkage. When you move that clockwise to full throttle it gets hung on the metal bracket. I was thinking there was a spring issue, sounds like maybe just lubricate and clean up the metal on both pieces that are catching?
One might guess the bottom section of the round part on top (where the spring and cable attaches) is slightly bent and comes into contact with the indented part ( largest visible piece with the large rust area on it) of the mounting bracket.
To me it looks like it was bent without the proper tang bender ( like I did to Tommy's this weekend) distorting it.sigpic
