Ok everyone I bought a Max II that's been a project to say the least. My machine is a 96 with the 18hp vanguard. I understand these are not fast, but the lack of torque is rather frustrating as it won't even break the tires in going up hill in the loose stuff. The rpm range seems fine and idles well, but its almost walking speed going up hills at or climbing anything at (WOT) and maybe 11 mph on flat ground. Both primary and secondary clutches seem to work as they should. I'm lost on what else to do, everything I've done is below. What am I missing? at the point that I might cave and take it to a shop.
Work accomplished:
New belt HP3003 and tightened
Cleaned both clutches
Adjusted chains
New idle jet
Cleaned and rebuilt carb
New Plugs
New AF
Oil Change
New fuel pump, lines, filter, cleaned gas tank
Greased everything
6 new wheels and tires
New throttle cable and adjusted
New lights
Added bilge pump
Serviced T-20 with Type F
Work accomplished:
Adjusted chains
New idle jet
New Plugs
New AF
Oil Change
Greased everything
New lights
Added bilge pump
