Hi: I am getting mentally prepared for the task of installing the tracks on my Max II.I bought an '03 slightly used in the spring.It came with the axle rails and wheel extensions installed when I got it but I removed them to narrow it in for the summer.It can access places(between trees etc.) better narrow.I will re-install the rails and wheel extensions and service the machine then I will be ready for the tracks.First question: I have read that some recommend removing the drive chains to the front axles to give the power train more power to the tracks.Any opinions on this? Also: I would appreciate any tips on installing the tracks.The information I have at this writing is to remove the center wheels and deflate the front and back tires,put the track around one tire then roll it on the other,install the center wheel and inflate the tires to tighten.Sounds easier than it will be for sure.These tracks would I should think have virtually no time on them possibly as little as an hour or two.How tight should the tracks be?
I'll greatly appreciate any informaion you can give me. Eldon
